MoI Parametric.
 1-18  19-27
7552.19 In reply to 7552.18
I tried Fusion 360, and for simple things, it makes my head hurt how complicated it is. The most frustrating thing for me is invisible constraints, and woeful documentation.
There are several actions that can only be assessed via contextual right-click.
Here's a nice bug, if you create curves (called sketches in Fusion) at world origin you cant move them (simple bug, but there's nothing in the GUI telling you why you cant move the curve). Since there is no snapping turned on by default, the natural response is to begin your curve off of the only reference object on the screen, the world origin dot.
For more intricate, pattern based stuff, like buildings or things with some symmetry, then Fusion is great, simply because its Parametric with Command History....want more windows in your building?...just increase a parameter and its booleaned and positioned for you.
I d/l Inventor last night, and its much better, but there's still alot of confirmation clicking (activate tool, use the tool, then right-click and select OK to complete the tool action).
It was such a pleasure to work back in Moi after that "alternative" CAD road trip.
Having said all that, Parametric/Command History are really, really nice CAD tools. I'd be interested to see how Michael would expose that in a "Moi" way.
7552.20 In reply to 7552.19
If MoI had Parametric/Command History it would be the superb. After trying it you will always want to have it because it it is so great.
www.samardac.com
you can also make some "save file" at several moments! ;)
7552.22 In reply to 7552.21
Unfortunately "save file" at several moments is not so functional like Parametric Tree or Timline.
You can not go back and modify some features, you can not disable feature, you can not go back at some moment and create some feature in the past.
With Save you will confuse very fast if you want to use it like Parametric tree.
Any way Save is the only Parametric alternative now for MoI :)
www.samardac.com
7552.23
Parametric modeling with some kind of history (or modifier stack kind, doesnt matter) would be nice. But for now for me going back and forth from Moi to Fusion is enough through STEP. So when I need some precise numbers, I import it later and continue to work. Fusion 360 is little bit clickfest in some cases, but it can be learned quickly.
7552.24
Hi All,
I'm happy with MoI not being parametric, but...
I've been playing with OpenSCAD for the last few months as part of hacking the Mendel90 open source printer project. For someone more used to modelling interactively, (using MoI, OnShape, etc) it can require a frustratingly complex number of boolean commands to achieve something that in MoI would be straightforward.
Now that I appreciate the elegance of it's parametric abilities - and accept inherit limitations, I began to wonder if a similar, identical or extended version of the openSCAD language, (with interpreter to MoI script) might be a good basis on which to make MoI parametric, without bloating MoI itself into something it was never intended to be. David Morrill and possibly others, made some headway on this kind of scripting interface a few years ago; unfortunately these projects seemed to have evaporated. Does anyone know anything different?
From the 'about' page, this is how Open S CAD is described:
"OpenSCAD is not an interactive modeller. Instead it is something like a 3D-compiler that reads in a script file that describes the object and renders the 3D model from this script file. This gives you (the designer) full control over the modelling process and enables you to easily change any step in the modelling process or make designs that are defined by configurable parameters."
Cheers,
Hamish
Indeed you must write some lines! ;)
http://www.openscad.org
A French tutorial ;)
http://fablab-lannion.org/wp-content/tutos/openscad/#/pageDeGarde
7552.26 In reply to 7552.24
Hi Hamish - in the future I would also like to add more support for scripting as a way of procedural object generation, which is indeed a form of parametric building but it has a high level of complexity for someone to learn. So it would likely be something that could optionally be used but not likely to be the only way to do parametric editing.
Parametric editing that is based off of editing things that you previously drew would probably be able to be used by a wider variety of people than one that required coding.
7552.27
"... but not likely to be the only way to do parametric editing."
Yes. Please take into consideration also something like the "Components" from Sketchup or Blocks from Rhino, or iLogic from Inventor. They are also very powerful parametric design approaches.
MoI can be more powerful than Sketchup (already is in many ways) but is drawn back by the lack of "components". Personally I think that if the MoI will have something similar to components will be a serious option for replacing Sketchup.
Show messages:  1-18  19-27
