MoI Parametric.
 1-10  11-27
7552.11 In reply to 7552.10
Michael, yep I understood. Anyway that feature whe you removing only one step from history would be great.
www.samardac.com
7552.12 In reply to 7552.7
Your plan sounds good, actually NX has the option where you can switch from History to History Free modelling however it's not as nimble as MoI.
7552.13 In reply to 7552.12
solidThinking Evolve is a great sub-d/ solid modeler with history but not ordered.
7552.14 In reply to 7552.13
dejule,
thanks for pointing to this software, I just checked a lot of video of it on youtube, and its ability to create organic forms with curves just blow me away, it is really impressed. I do not know if you need Sub-D in this situation :) Need to dig in it a bit more!
www.samardac.com
7552.15
Hay guys, just want to share some thoughts.
I tested Fuison 360 for about 2 weeks tried to make my project in it I even created bunch of shortcuts using AHK. And what I can say the things that I made in MoI for 30 min I made in Fuison for about a half of day. Fusion have the greatest Idea in it but workflow is terrible... I back to MoI and NVil because deadline of my project was finished 2 days ago and I still do not finish model...
Wat I learn is that MoI for Hard Surface is superb and all that scripts made my work SUPER fast. Absolutely the same thing with NVil, TSpline has a lot of advantages but it lucks so many instruments and features so workflow become real pain and you have a lot of time to get used to it. What I'll miss it a lot after fusion is Parametric ability it is really great feature!
EDITED: 24 Aug 2015 by ANDREI SAMARDAC
7552.16 In reply to 7552.15
Hi Andrei,
Got mostly the same feeling about fusion360, horrible experience for my way of working. 'Basic' curves drawing is so slow compared to Moi.
I can't understand how people can still develop a modeling package this days without having custom shortcut options.
(First time I eared about AHK, that might be a workaround).
The whole cloud system is very irritating too.
I'm still looking for the holly grail, aka a good hybrid nurbs/sds package, but with no success.
Solidthinking is much easier to pick than Fusion, but the 'polynurbs' toolset is very primitive. I do not expect to have the poly tools to build an
human face, but there are so many simple modeling function missing that the only solution would be to use an external poly modeler, limiting
the need of such software (ST Evolve is over 2k).
At least custom shortcut are possible, except for the navigation ... go figure. (makes me very grateful to all the navigation options we have in MoI :))
7552.17 In reply to 7552.16
Hi PaQ,
" Solidthinking is much easier to pick than Fusion, 'polynurbs' toolset is very primitive"
Yes... When I saw it, I leave this app because I need SUBD. But anyway their parametric features are great, I really like how you can work with it!
I decided to make some little review of Fusion, may be it will halp others to take decision of using it.
I will explain my thoughts from point of vision of Concept Designer. In my work when I made things for product design I do not need absolute precision, in my stage I gave 3D model of mechanism and create design above it. After design is approved my model use another person - 3D modeler that creates precis nurbs model for production. So may be my workflow will have some effect on my review, because I prefer to work super fast only with shortcuts to not loose my inspiration.
Also my English is not very good so I can say something wrong so excuse me :)
Fusion 360:
Shortcuts:
It has no any shortcut, oh they have some but you will never use them because they are for operation that you use very rare. Vital commands like Pull and Edit Form has no any shortcuts.
So you have to be ready for endless clicking...
Navigation:
It has that famous useless Navigation Cube in upper right corner, my personal opinion is, it is the only progressive feature that AD adds to their apps :D
There is no any way to go into Right or any other ortho thews except clicking on that Cube or in Browser.
Drawing:
You always have to create plane to draw and having this limitation it has no goo toolset for this. Instead it has a lot of tools that are all nearly not so good as one CPlane picker in MoI.
Check how many tools and they are absolutely useless if you want to set CPlane to organic stuff you made with TSplines you just can not do it, it work only with hard surface.
Snapping:
There is no snapping at all when you model and it is terrible, snapping is only when you drawing. To move with snap there is one command that in MoI calls Orient. Snaping is not bad when you draw but in MoI it is thousands time more advanced and MoI has real Construction lines.
Moving:
To move you always have to run command from context menu, in fusion you always have run commands from context menu it is so boring... In MoI you just select object and Move, in MoI 3.0 Michael implement stright snap moving with shift and it is really great.
Objects:
This theme is absolutely horrible... It confuse me most of all. In Fusion objects calls Components. And when you start project you are in top most component, so than you have to create components everytime you want to create separate objects. All sketches can be stored or in Active object or in top most or in parent. To store sketch in Component you have to activate it, but you always forget to make it because in Fusion there is no good way to see if component is activated. It has option to make all components transparent except active but it looks terrible when you have big model and you have to click about 5 clicks to go to setting and disable it... So if you forget to store sketch in component you can not isolate component with sketch because sketch will lay some where else.... Then.... :D If you want to extrude from sketch and cut with this geometry it will cut all geometry from all components that it meets, so to cut only one you have to hide all others you can do it by hiding objects (context menu as always :D) if you have more then 2 objects to hide it become so boring, or you can isolate your object and cut it, but if you forget to store you sketch in this object it is impossible :D There is no simple way to copy sketch from one component to another only complicated where you have to go to one sketch copy it and than go to another to past :% why not just copy it form explorer and past?... Do not going to confuse you with further imperfection of Fusion workflow with components :D. A... forget, Component have bodies and it is geometry that it holds and this thing confuse me from first day, I thought I have to work with bodies but, bodies just geometry inside component and this geometry can be hidden only from explorer, we can not isolate it, another words we can not handle it like Component, may be this body have sense but for me it looks like way to complicate things that are already complicated, also when you create object it by default creates bodies, so it is very easy to forget to change it to New Component, brr.... :D
Also...))) If you hide object and have big model with a lot of components it is real pain to unhide it because you can unhide it only from browser, but to do it you have to find it in that browser :D It is so hard task so you can break your eyes because selected object is so bad highlighted some tinny line under it and this is it, even if you use function find in browser you can not see highlited object.
TSpline:
I do not going to tell a lot of words about it, it have advantage that you can create T like cage but I thing it is all. It absolutely sucks against good polygonal modeler, in terms of polygonal modelling. May be for TSpline no need to have all that function because it can compensate them by using NURBS tools after you create base form, but have you tried to make it in Fusion? It is so hard because you can not eve set CPlane to this TSpline object. So to cut simple hole on organic TSpline you have to create nurbs object that replicate continuity of TSpline object than set CPlane from this :D
I work in NVil and can compare TSpline with it, it have about 30% of tools and workflow from NVil.
Render:
It has to few parameters and I like it but I could not mange to have things so nice and bright like in KeyShot, for me it looks not so expressive like KeyShot.
Patch:
This room is really good, it has all instruments to work with surfaces, it has loft with Tangent, Patch and others... But you will laugh, it has Sweep only with one rail :D
I do not test Cam and animation. Want to say that animation do not support Assembly. So if you joined components you can not animate it :%
But the great feature that fusion has it is Parametric Timeline, it is really great, you can go back change things, create things where you etc? you have absolutely freedom. It is not a tree like in another aps it is timeline where you can navigate through.
So in conclusion, Fusion is very simple it has very few settings and it is good! It has good idea to combine SubD and Nurbs, also they try to combine Cam and Animation with render, but as always happen when people try to combine too many stuff final product is not so good. But as we can say it was good effort :)
PS
I tried Fusion for 2 weeks and delayed deadline, because could not finish my model. I thought I can do it because I thing speed will be the same like in MoI and NVil, but it is 3-4 times slower some times much more.
I got 2 lessons from this experience, I learn how other CAD works, learn some nice ideas and fails and the main thing, I become absolutely Master in Clicking!
EDITED: 25 Aug 2015 by ANDREI SAMARDAC
7552.18
I'm testing Inventor and have to say Fusion 360 is stripped-down and messed up version of Inventor.
All that stuff that drives me crazy in Fusion is very good defined and structured in Inventor.
www.samardac.com
7552.19 In reply to 7552.18
I tried Fusion 360, and for simple things, it makes my head hurt how complicated it is. The most frustrating thing for me is invisible constraints, and woeful documentation.
There are several actions that can only be assessed via contextual right-click.
Here's a nice bug, if you create curves (called sketches in Fusion) at world origin you cant move them (simple bug, but there's nothing in the GUI telling you why you cant move the curve). Since there is no snapping turned on by default, the natural response is to begin your curve off of the only reference object on the screen, the world origin dot.
For more intricate, pattern based stuff, like buildings or things with some symmetry, then Fusion is great, simply because its Parametric with Command History....want more windows in your building?...just increase a parameter and its booleaned and positioned for you.
I d/l Inventor last night, and its much better, but there's still alot of confirmation clicking (activate tool, use the tool, then right-click and select OK to complete the tool action).
It was such a pleasure to work back in Moi after that "alternative" CAD road trip.
Having said all that, Parametric/Command History are really, really nice CAD tools. I'd be interested to see how Michael would expose that in a "Moi" way.
7552.20 In reply to 7552.19
If MoI had Parametric/Command History it would be the superb. After trying it you will always want to have it because it it is so great.
www.samardac.com
you can also make some "save file" at several moments! ;)
7552.22 In reply to 7552.21
Unfortunately "save file" at several moments is not so functional like Parametric Tree or Timline.
You can not go back and modify some features, you can not disable feature, you can not go back at some moment and create some feature in the past.
With Save you will confuse very fast if you want to use it like Parametric tree.
Any way Save is the only Parametric alternative now for MoI :)
www.samardac.com
7552.23
Parametric modeling with some kind of history (or modifier stack kind, doesnt matter) would be nice. But for now for me going back and forth from Moi to Fusion is enough through STEP. So when I need some precise numbers, I import it later and continue to work. Fusion 360 is little bit clickfest in some cases, but it can be learned quickly.
7552.24
Hi All,
I'm happy with MoI not being parametric, but...
I've been playing with OpenSCAD for the last few months as part of hacking the Mendel90 open source printer project. For someone more used to modelling interactively, (using MoI, OnShape, etc) it can require a frustratingly complex number of boolean commands to achieve something that in MoI would be straightforward.
Now that I appreciate the elegance of it's parametric abilities - and accept inherit limitations, I began to wonder if a similar, identical or extended version of the openSCAD language, (with interpreter to MoI script) might be a good basis on which to make MoI parametric, without bloating MoI itself into something it was never intended to be. David Morrill and possibly others, made some headway on this kind of scripting interface a few years ago; unfortunately these projects seemed to have evaporated. Does anyone know anything different?
From the 'about' page, this is how Open S CAD is described:
"OpenSCAD is not an interactive modeller. Instead it is something like a 3D-compiler that reads in a script file that describes the object and renders the 3D model from this script file. This gives you (the designer) full control over the modelling process and enables you to easily change any step in the modelling process or make designs that are defined by configurable parameters."
Cheers,
Hamish
Indeed you must write some lines! ;)
http://www.openscad.org
A French tutorial ;)
http://fablab-lannion.org/wp-content/tutos/openscad/#/pageDeGarde
7552.26 In reply to 7552.24
Hi Hamish - in the future I would also like to add more support for scripting as a way of procedural object generation, which is indeed a form of parametric building but it has a high level of complexity for someone to learn. So it would likely be something that could optionally be used but not likely to be the only way to do parametric editing.
Parametric editing that is based off of editing things that you previously drew would probably be able to be used by a wider variety of people than one that required coding.
7552.27
"... but not likely to be the only way to do parametric editing."
Yes. Please take into consideration also something like the "Components" from Sketchup or Blocks from Rhino, or iLogic from Inventor. They are also very powerful parametric design approaches.
MoI can be more powerful than Sketchup (already is in many ways) but is drawn back by the lack of "components". Personally I think that if the MoI will have something similar to components will be a serious option for replacing Sketchup.
Show messages:  1-10  11-27
