getting ready for export
All  1-6  7-11
7551.7 In reply to 7551.6
Another way to inspect a surface that says it has bad trims on it is to select the surface and then run CreateUVCrv - when it asks you to select any additional curves just push enter. That will stick the UV space boundary curves into the Top view, use ZSA (Zoom selected all) to zoom to them. There will be a rectangle for the surface's outer boundary and then all the UV space versions of the trimming boundary inside of that. If some of those looks weird and chaotic like squiggling around or shooting off strangely off the boundary then that's a damaged UV curve, those can be repaired by untrim + retrim.
7551.8 In reply to 7551.7
Aha! :)
Invaluable Michael. Thanks!
7551.9 In reply to 7551.8
Thought I made some beautiful blends on the hulls... Turns out there are some horrible self intersecting/twisted trims... :o
Repaired! probably spend a few hours going over everything in another week or so when it's done....
Thanks again....
7551.10 In reply to 7551.9
No problem Burr! The model is really cool!
7551.11 In reply to 7551.10
Thanks michael. I will make a post about it when im done. Im making it for polynesian voyaging society and their UH education program.
Show messages: All  1-6  7-11
