getting ready for export
All  1-3  4-11
7551.4 In reply to 7551.3
Hi Burr, well those weren't the only problems that was just the majority of them about that wrong edge flag thing.
There are a couple more ones like a couple edges out of tolerance (a gap like 0.01 units instead of at least 0.001 units as the edge was marked), and a couple of edge endpoints that are not totally lined up with each other. There aren't as many of those but a couple of those are potentially worse problems than that edge flag thing, like there may be one slightly messed up edge in the one that has the endpoints not matching by a fair amount... Some of them are errors in the edge structure in the UV part of the trim edge where it's hard to judge just from a numeric value how much the error actually is.
But out of like 70 objects flagged, 58 of them are just that "iso flag not as expected" error, those are the ones named block_rope_tie, block_rope_tie_2, block_rope_tie_3, and tail_net.
7551.5 In reply to 7551.3
And if you want to get a more narrowed down view of the specific area of the model it's complaining about, select the object and run Explode to break it into individual surfaces and then run SelBadObjects, that will then show you the particular surfaces that have the "bad" stuff in them and you might look over those to see if there is a noticeable problem in their trim edges.
I think there used to be a command called ShowBrokenEdges or ebroken but it seems to have gone away when some different commands were merged into one "ShowEdges" command.
7551.6 In reply to 7551.5
Thanks again. I'm going to mark this thread and go back to things at finalization time and look at cleaning things up for a polish.....
I think the "rope and netting", I'll just redo, as it is just slapped out early in the model... You can see it is just not really "well formed" netting.
But some of the surfaces on the hulls and masts etc, I want to be sure are quality...
I'll use your input to inspect closely and rebuild when I find those bad trims....
7551.7 In reply to 7551.6
Another way to inspect a surface that says it has bad trims on it is to select the surface and then run CreateUVCrv - when it asks you to select any additional curves just push enter. That will stick the UV space boundary curves into the Top view, use ZSA (Zoom selected all) to zoom to them. There will be a rectangle for the surface's outer boundary and then all the UV space versions of the trimming boundary inside of that. If some of those looks weird and chaotic like squiggling around or shooting off strangely off the boundary then that's a damaged UV curve, those can be repaired by untrim + retrim.
7551.8 In reply to 7551.7
Aha! :)
Invaluable Michael. Thanks!
7551.9 In reply to 7551.8
Thought I made some beautiful blends on the hulls... Turns out there are some horrible self intersecting/twisted trims... :o
Repaired! probably spend a few hours going over everything in another week or so when it's done....
Thanks again....
7551.10 In reply to 7551.9
No problem Burr! The model is really cool!
7551.11 In reply to 7551.10
Thanks michael. I will make a post about it when im done. Im making it for polynesian voyaging society and their UH education program.
Show messages: All  1-3  4-11
