Little problem with sweep
All  1-3  4-7
7548.4 In reply to 7548.3
Hmmm,
I think I really will have to alter my way of working: Since MOI is so
intuitive, I proceed always so fast, and very often just delete stuff which
is not working as I want and go another way, as I did with this one.
In short, somehow that file wit that problem as you see it on the
pics is no more :-(
The only thing I can say is, that I usualy do a rebuild with all curves I
work with in order to get as little CPs as possible. In case of such sweep
things, I always look, that the amount of CPs in the shapes is similar.
Anyway,
problem is gone for now, if I run into something like that again, I will
keep the file.
Sorry and Thanks,
Heiner
Here is a curve made with freeform command, which yields a good freeform sweep, but a bad flat sweep.
7548.6 In reply to 7548.5
You won't use 'Flat' option Sweep for such a shape, the 'Flat' option is mainly used to control or force a multi sided profile in either X,Y or Z direction along an axially produced rail.
For example; the attached file produces the opposite what you have Bad 'Freeform', Good 'Flat'.
7548.7
Hi
sometimes if your profile gets flipped or you select the wrong part of it the sweep does a 180 twist as if sweeps
I would try flipping the left hand circle with points on 180 degrees and see if it changes the sweep error
he is an example the centre circle has the wrong orientation
cheers
shayne
Show messages: All  1-3  4-7
