Refit Curve
All  1-3  4-8
7540.4 In reply to 7540.3
the post with the command refferences you directed me to was a great help.
One more question: If I want to use keys on the numerical keyboard, how do I
indicate that in the list for the keyboard shortcuts?
Heiner
7540.5 In reply to 7540.4
Hi Heiner,
For those put in the key name on the left-hand column like this:
Numpad0
Numpad1
Numpad9
Numpad.
Numpad*
Numpad+
Numpad,
Numpad-
Numpad/
The list of all possible key names is in that same help topic too, just a little above the command names:
quote:
The key can be defined using a letter (like "A") or one of these labels: F1 - F12, UpArrow, DownArrow, LeftArrow, RightArrow, Home, End, PageUp, PageDown, Insert, Delete, Backspace, Space, Numpad0 - Numpad9, Numpad.*+,-/ . The key can be prefixed by one or more of these modifiers: Ctrl+ , Shift+, or Alt+ (or Cmd+ on OSX).
Hope this helps!
7540.6 In reply to 7540.5
That really helped,
and some of my commands are now working as intended ... but ... others not yet.
I prefer working with one lage viewport therefore I want to set up my numpad in a way,
which makes it possible to access every view. Usualy I use em the following way:
0 = 3D View
1 = Bottom
2 = Front
4 = Left
5 = Top
6 = Right
8 = Backview
The views 3D, front, top and left work,
right, back and bottom do not. I already tried to add
a Ctrl prefix, like you have to use it when you klick
the view buttons, but with no result ...
What do I do wrong here?
Heiner
7540.7 In reply to 7540.6
Hi Heiner, actually ctrl does not have any special effect when clicking on the view buttons - it's just a second click (either ctrl held down or not, it doesn't matter) on the already activated view button that will switch it back and forth from the reverse view.
Check out here for what script to put in for the "command" part of the shortcut key in order to jump directly to a particular view:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3808.2
7540.8 In reply to 7540.7
That was really of great help Michael,
that will speed up my workflow even more!
Thank you!!!
Regards,
Heiner
Show messages: All  1-3  4-8
