Garlic
All  1  2-5
7539.2 In reply to 7539.1
Here is Garlic2 script, which enables longitude curves to also be created.
Network may be used if there are both latitude and longitude curves.
In order to plot only longitude curves, set uDensity = 0 and set vDensity > 1.
For 6 longitude curves, set vDensity to 7.
For just latitude curves, set vDensity to 0, and uDensity > 2.
7539.3 In reply to 7539.1
Ha, virtual garlic, that's great Brian! I must admit I am lazy and just use chopped garlic from a jar.
7539.4
Looks like the script would make a nice hot air balloon canopy, too. What does the other end look like?
7539.5 In reply to 7539.4
Thanks Michael.
Hi John,
The bottom is tapered. The lofted horizontal curves bottom has a flat spot.
It is not really teardrop shaped.
The "natural" balloon is "flat" at the peak point, when inflated with open (bottom).
The tension minimizing math is advanced. I have not found a simple formula yet, nor an explanation of
how to plot the teardrop from the differential equations.
I previously did a "mylar" balloon script.
-Brian
(I would also consider the garlic script to be a 2D curve generator, for other purposes.)
EDITED: 14 Aug 2015 by BEMFARMER
Show messages: All  1  2-5
