Unwanted plane artifacts exporting to .obj
All  1  2-3
7537.2 In reply to 7537.1
Hi Yophie, probably what's happening there is both those programs are having difficulty in properly triangulating a many sided polygon in the .obj file. It's fairly difficult to do a good job of converting complex concave n-gons into triangles and it's pretty easy for there to be errors with triangles kind of leaking outside the polygon boundary. Also most programs don't export n-gons like MoI can and so complex n-gon triangulation tends to be an under tested area in many programs.
When you export out from MoI try using the option for "Output: Quads & Triangles" and not "Output: N-gons", and that will probably work better for you:
7537.3
worked perfectly, thank you! :)
Show messages: All  1  2-3
