Microsoft Surface and Moi
All  1-2  3-5
7513.3 In reply to 7513.1
I've been using moi on a surface 3 Pro works OK but I get a lot of lock ups and graphic problems
Michael sorry I have not reported any errors , been to busy at work. :)
7513.4 In reply to 7513.3
Hi Steve, if you turn off multithreading in the display engine it should fix that, it seems that the video driver with the surface 3 is sensitive to multiple threads being used.
See here for how to set it: http://moi3d.com/forum/index.php?webtag=MOI&msg=7385.3 , you need to edit moi.ini and set DisplayThreadLimit=1 in there.
Once you do that do you then get stable behavior?
7513.5 In reply to 7513.4
I use Moi3D on a Surface 3 Pro and I am delighted with the performance ( Moi3D with mobility, the TOP !) .
I would even say that it is almost the only software that is really suitable for the use of the stylus ...
If I have not already bought this tablet, I think I will have missed something ;)
Bear17
Show messages: All  1-2  3-5
