Hi Stefan, so the first step is to copy the MoI installation folder ( C:\Program Files (x86)\MoI 3.0 ) over to the USB stick.
Then to find your license key file and moi.ini file, open the Start menu (push the Start button or push the Win key on the keyboard), and then type in %AppData%\Moi and push Enter.
That will open up the folder where your moi_v3_license.key and moi.ini files are stored, copy those onto the USB key as well so they are in the same folder as MoI.exe . Also if your v3 license is an upgrade license type also copy your moi_v2_license.key file over as well.
Once you have copied those things over, you'll have everything set up to run MoI.exe directly from the USB stick when you plug it into the computer.
Hope this helps!
