import stl to vol format in Monolith
All  1  2-3
7496.2 In reply to 7496.1
Hi Del, sorry I'm not familiar with Monolith - this here is the MoI forum which is a totally different software program from Monolith.
Does Monolith have its own discussion forum? If so then you might want to post your question there.
If the only way to convert from .stl to .vol is by using Grasshopper, then you'll need to use Rhino to do that - Grasshopper is a Rhino plug-in and both Rhino and Grasshopper are also different software programs than MoI which is the one that this forum is about.
7496.3 In reply to 7496.2
You can use this to set a path to an stl inside of grasshopper:
http://www.grasshopper3d.com/xn/detail/2985220:Comment:971228
But I cant give you a step by step because I have the 64 bit rhino.....
Show messages: All  1  2-3
