Bug Distortcurves ?
All  1  2-6
7492.2 In reply to 7492.1
Hi Pilou - I'm not seeing what the bug is there - it's normal for sliders in MoI to work with a predefined range. Then if there is an input control next to it you can directly input values outside the slider range if you want. When you do that it does not modify the range of the slider though so if you go back and use the slider again you will see the same behavior as you did before you put in your custom 'out of range' value.
That's just normal behavior, not a bug.
If there is something else that you're trying to show there I guess you'll need to explain it in a bit more detail.
7492.3 In reply to 7492.2
I want use the cursor from 200 to 0 !)
And more generally with the number input by the user!
And for the bug i had put a "?" :)
7492.4 In reply to 7492.3
That's just not how sliders work in MoI - editing a custom value does not change the slider range. That's normal behavior and not a bug.
But if you want you can edit the .htm file and change the range values for the slider to make it permamently go between 0 and 200.
Open the file in a text editor and find the <moi:Slider> element in there, the ranges are set by the values min="" mid="" and max="".
If you set them to min="0.0" mid="100.0" max="200.0" then your slider will go between 0 and 200.
7492.5 In reply to 7492.4
Hoppefuly we can make that! :)
Excellent! :)
Will be very cool with LineWeb for example! :)
EDITED: 10 Jul 2015 by PILOU
Show messages: All  1  2-6
