How to change moi3d UI font after Linux update?
7491.1
Hello,
how can I change the blurr UI font applied after an Linux update?
S.
Size: 301.7 KB, Downloaded: 85 times, Dimensions: 1532x874px
7491.2 In reply to 7491.1
Hi simba - the font used by MoI is set under moi.ini, go to Options > General > "Edit .ini file" button. Then inside there the font is set under
[UI]
UIFontName=Arial
You can set that to a different font to see if a different font works better.
However, it's pretty likely that it's not the font itself that is making things blurry but rather a bug in Wine's font rendering. You will probably have to try a different version of Wine to make the blurriness go away, try the latest development version and see if that helps.
7491.3 In reply to 7491.2
Thank you for the hint!
I case someone else runs into the same problem:
The fix can be found here: http://askubuntu.com/questions/219791/improve-gui-appearance-of-wine-applications
For the relevant commands, have a look at the attached picture.
S.
Size: 84.7 KB, Downloaded: 84 times, Dimensions: 728x602px
7491.4 In reply to 7491.3
Greetings All,
The best and quickest solution to the UI font problem is to set the UIfontName=Droid in the moi.ini file.
Just let the system use a native font that renders well by default, rather than trying to force Arial to display correctly.
You will be much more pleased using Droid on your linux machine!
