Moi to solidworks
7487.1
Hi all,
just evaluating MOI after being a solidworks user for 10 years. I like the sculptural nature of the program, but was wondering if I could take a shape back into solidworks for more engineering functions.
Also, are the forms created with MOI only one solid part, or can assemblies of shapes be attached or mated to one another?
thanks for any help
ken
7487.2 In reply to 7487.1
Hi ken, yes you can take a model you construct in MoI back into SolidWorks. I'm pretty sure SolidWorks can import MoI's primary 3DM file format directly, it may be listed as the Rhino 3DM format. Or also another method is to export a STEP (.stp) file out from MoI and then import that into SolidWorks.
re: assemblies - yes you can create assemblies of multiple parts in MoI as well. The way it works is that you can just create multiple objects (multiple solids, multiple curves, multiple disconnected surfaces, whatever...) within the same one editing enviornment, there isn't any special part versus assembly mode.
For Mating parts, MoI does not have a constraint mechanism so it's a little different but you can use object snaps when picking points and the Transform > Orient tools are useful for aligning parts with each other, see an overview of the Orient tool here:
http://moi3d.com/3.0/docs/moi_command_reference8.htm#orient
7487.3 In reply to 7487.2
Hi michael,
thanks for the answer. Yes, I see a 3dm import available in SW.
one other question...can you point me in the direction for an explanation of how to incorporate scripts? I was reading a tutorial of the car on the front page of the MOI gallery and it talks about installing something called a dsub?
Ken
7487.4 In reply to 7487.3
Hi Ken - for installing scripts it can vary depending on the specific type of scripts. Some scripts are meant to be pasted directly into a shortcut key. Other ones are more complex plug-ins that create new commands for MoI to run.
For the kind that creates new commands, to install those you have to unzip the script files, then the files (usually there will be 2 of them, a .htm and a .js file) need to be copied into MoI's \commands sub-folder to make them seen by MoI.
The commands folder is located inside the main installation folder for Windows, like C:\Program Files (x86)\MoI 3.0\commands, and for the Mac right-click on the .app icon and choose "Show package contents" and inside there go to drive_c/moi/commands.
Once the files are copied into the commands folder that makes a new command available to MoI. To trigger the command set up a shortcut key with the command name in the right-hand column that's labeled "command". The command name is the base common name of the .htm and .js files, so for example if the plug-in command has 2 files named NewCommand.js and NewCommand.htm, that makes a command named NewCommand available to MoI and you would put in NewCommand for the shortcut key.
7487.5 In reply to 7487.3
Hi Ken, also for the car tutorial there are links for where to get the sub-d plugin on the second page of the tutorial here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7389.2
7487.6 In reply to 7487.5
Hi michael,
thanks for the help. I did install the car scripts and those extra buttons. Very cool! And I tried importing a simple file into my solidworks and that worked too. Is keyshot the rendering program of choice?
Ken
7487.7 In reply to 7487.6
Keyshot is the more easy render! But not a low price! :)
7487.8 In reply to 7487.6
Hi Ken, that's great! I hope that MoI will be useful for you to use in combination with SolidWorks.
Keyshot is a very good rendering program, just like Pilou mentions above somewhat expensive.
Another one that you might try is SimLab Composer.
