Creating a complex ridge
All  1-5  6-9
7483.6 In reply to 7483.5
Thank you for your detailed description. That gave me a precise hint how to do it. I worked through all tutorials I could find on blend on youtube. But just now I realized, that the reason I could not do it was, that the extruded objects were solids... If I extruded them without caps, it worked like a charm... And blend does only work on edges, NOT on curves! Did not know that.
I changed the extrusion path of one curve and got it closed! Yes!!!
Before it was not closed. Only a joined surface. Is there some kind of auto repair or detection to find out where exactly your model is not closed?
I really had to get used to modeling with surfaces. Normally I model with solids only.
Alle the Best,
Philip
7483.7 In reply to 7483.6
<< And blend does only work on edges, NOT on curves!
This is not right! ;) (but maybe I don't understand the translation)
A little trick : click on the extremities near between the curves!
EDITED: 6 Jul 2015 by PILOU
7483.8 In reply to 7483.7
<<This is not right! ;) (but maybe I don't understand the translation)
Hey Pilou,
blend does work on curves. You are right, but it does sth. completely different than on an edge. That´s what I meant.
Philip
7483.9 In reply to 7483.8
No problem! :)
Show messages: All  1-5  6-9
