external monitor no bueno
7477.1
Hi Michael (et al),
I've been trying to use MoI with a new Asus external monitor and the application just freaks out every time I open it. It's different bugs every time, from crashing when I try to open files, to the whole window streaking and flashing when I try to move/resize, to just plain freezing in the middle of commands.
I'm using the Mac version, so this is probably at the edge of the realm of support, but the 13" workspace on my laptop is killing me :\
Yophie
7477.2 In reply to 7477.1
Hi Yophie, what version of Mac OS X are you running and how is the Asus monitor connected ?
Martin
(TpwUK)
7477.3 In reply to 7477.2
OS 10.10.3, thunderbolt
7477.4 In reply to 7477.1
Hi yophie, Apple made some significant changes in the way multiple monitors work in OSX Mavericks, and XQuartz which MoI currently uses still has not caught up to those changes.
I think it's scheduled to be fixed in a future version of XQuartz, but for now you should probably be able to solve the problem by changing the setting to return to previous style multimonitor behavior. That setting is under System Preferences > Mission Control - uncheck "Displays have separate Spaces" there. You will then need to reboot your system in order for this change to take effect.
Hopefully that will stabilize things for you.
7477.5 In reply to 7477.4
Perfect! Thanks, Michael.
