Curve from two view
All  1-2  3-7
7463.3 In reply to 7463.2
Thank You! Michael
7463.4
How would you get history to update on this so if either master curve are changed the result redraws ?
thanks
shayne
7463.5 In reply to 7463.4
Hi shayne,
You can do this by selecting the output curve, and then enabling history updates on it by going to Edit > History > "Enable update" button.
Then when you edit the input curves the output will be regenerated.
It will only work if there is only one output curve though, it won't work if multiple curves are being generated in one go. Also make sure you keep the input curves planar while editing them.
Michael was too speed:)
7463.7
Thanks guys
thats useful , I use the flow command with history and its brilliant
cheers
shayne
Show messages: All  1-2  3-7
