Fillet help (another)
All  1-5  6-10
7462.6 In reply to 7462.5
wow thank you for all the feedback chaps, and also apologies for digging up that old fillet chestnut.
Interestingly, I've not used the 2-rail sweep method before (usually I just loft two curves).
Avoiding segmentation seems to be the key, but it happens to easily it's a bit frustrating. If you look at the original model attached and start diagnosing it by selecting naked edges, individual edges etc it all looks, well, pristine. (I did say "looks" ;) )
It's not until we start adding fillets, or doing a shell operation that problems become apparent as it all goes to Sh!!@
Is there any other methodology for diagnosing problem areas before taking a surface further towards the end result ?
7462.7
Oh dear.
While the fillet works fine (with rebuild of joined curves and 2-rail sweeps, yay) now the fillet operation has decided to do an unwanted "cleanup" of the rest of the surface.
Hehe.. I swear I'll never feed the fillet function after dark, or let it near water again.
Size: 118.1 KB, Downloaded: 48 times, Dimensions: 1200x450px
7462.8 In reply to 7462.6
Hi Rico,
It can be good to view it with a high detail tessellation to see if it's got any weird lumps or creases in it.
To do that, set up a shortcut key with this as the command part:
SaveAs c:\test.obj
Then when you push space you'll be exporting to a temporary .obj file - crank the slider all the way to the right and choose "Display shaded" and zoom in a ways to look at your surfaces.
7462.9 In reply to 7462.7
Hi Rico,
> Oh dear.
It's built into filleting that it tries to remove "topological edges" from the model if possible, which means it will try to merge 2 coplanar plane fragments into a larger plane.
In MoI v4 I can see about disabling that but for now there isn't any way to turn that off, sorry.
7462.10
>SaveAs c:\test.obj
Superb tip.. thank you Micheal
>It's built into filleting that it tries to remove "topological edges" [SNIP]
Ahh it's good to know I'm not just going mad and seeing things. (joking aside, was just wondering if I was missing an option)
Thank you again
Show messages: All  1-5  6-10
