Fillet Help
All  1-2  3-8
Hi Chris
Moi solid Text in Arial for 948, approximately the same size as yours, fillets nicely at 1 mm.
7456.4 In reply to 7456.3
Moi Solid text in Futura Book is the same as your extruded 948...
7456.5
Hi Chris:
Michael showed right where are problem areas :)
I suggest a little modification mantaining main shape
Select text's curves,copy and move
turn on points,delete that little line and move vertex
in case of -4- you'll have two triangles
now you'll able to fillet to 1,5 mm
file attached: M
EDITED: 15 Dec 2020 by M-DYNAMICS
7456.6 In reply to 7456.5
Ecellent trick!
Sorry what is the meaning of "4-i","4-e" ? (Internal / external ? )
EDITED: 18 Jun 2015 by PILOU
7456.7 In reply to 7456.6
Yes...it's for indetify outern triangle and inner triangle,about -4- on third image,it's a close up and could be not clear which area i'm showing
4-i = 4 inner (interno)
4-e= 4 outern (esterno)
forgive me i did it quickly...i mix Italian and English..some tolerance.. :)
Many times i found same problems when filleting solid fonts,so i decided to show this "shortcut": simplify or use rebuild command to clean points of font splines before extrude.
M
7456.8 In reply to 7456.7
THx for the info! :)
Show messages: All  1-2  3-8
