Fillet Help
7456.1
I'm trying to do a simple fillet on some extruded numbers and it keeps failing. I'm at a bit of a loss.
Does anybody have any advice?
Chris
7456.2 In reply to 7456.1
Hi Chris - often times text can have badly formed curves, which don't affect their original purpose of 2D printing but can be bad for 3D geometry purposes such as filleting.
In your case here there are some small sized segments which then converted into very thin slivery faces in the extrusion and those will complicate filleting.
Here I've circled and zoomed in some to show you the problem areas:
The filleting will fail if it would cause a face to be totally consumed away to nothing, that will be easy to have happen with such small slivery faces in the shape.
Then the other thing that is difficult for filleting is dealing with very pronounced angles between pieces which is common with text.
These issues can tend to make filleting of text to be difficult.
Hi Chris
Moi solid Text in Arial for 948, approximately the same size as yours, fillets nicely at 1 mm.
7456.4 In reply to 7456.3
Moi Solid text in Futura Book is the same as your extruded 948...
7456.5
Hi Chris:
Michael showed right where are problem areas :)
I suggest a little modification mantaining main shape
Select text's curves,copy and move
turn on points,delete that little line and move vertex
in case of -4- you'll have two triangles
now you'll able to fillet to 1,5 mm
file attached: M
EDITED: 15 Dec 2020 by M-DYNAMICS
7456.6 In reply to 7456.5
Ecellent trick!
Sorry what is the meaning of "4-i","4-e" ? (Internal / external ? )
EDITED: 18 Jun 2015 by PILOU
7456.7 In reply to 7456.6
Yes...it's for indetify outern triangle and inner triangle,about -4- on third image,it's a close up and could be not clear which area i'm showing
4-i = 4 inner (interno)
4-e= 4 outern (esterno)
forgive me i did it quickly...i mix Italian and English..some tolerance.. :)
Many times i found same problems when filleting solid fonts,so i decided to show this "shortcut": simplify or use rebuild command to clean points of font splines before extrude.
M
7456.8 In reply to 7456.7
THx for the info! :)
