Designed with MoI
All  1  2-5
7454.2 In reply to 7454.1
Hi scott, wow that is a fabulous and unique work from CNC!
If you get a chance it would be cool to see it in the gallery: http://moi3d.com/gallery/
> Is there actually a way in a script to find/define the polygon of a closed curve?
It's possible to use the array factory to replicate a point along a curve to make a polygonal version of the curve. Check out the ReconstructCurve plugin for an example: http://kyticka.webzdarma.cz/3d/moi/#ReconstructCurve
7454.3
Cool work, respect!
7454.4
This is kind of moving backwards from Rapid Prototyping and all Digital models, but I need to build physical car model (scaled). I would like to know if there are any ways to "automatically" slice a model into user defined thickness for generating templates. Templates would be printed and used with urathane foam layers to recreate the MOI model.
Bob
7454.5 In reply to 7454.4
Hi Bob, there is a tool from Autodesk that is specifically focused on generating thick slices from models to build them using laser cut pieces.
I think it's this one here: http://www.123dapp.com/make
Importing your model into that is probably the easiest way.
Show messages: All  1  2-5
