Viewport Hangs...
All  1-3  4-11
7436.4 In reply to 7436.3
Trial and error, had some OBJs in there from the OBJ importer, seems to have something to do with them (though they are very low poly)
7436.5 In reply to 7436.1
Hi Rich, typically stuff like that is an indication of video driver problems. If you continue to see this problem you may want to try updating your video driver to the latest version and see if that helps any. Also another thing you can try is to set an option to disable multi-threading in the display engine, sometimes that causes problems with some drivers. There's a description on how to set the option for that here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7385.3
7436.6
Cheers Michael I'll give it a shot next time I have some oddball things happening!
7436.7 In reply to 7436.6
Hey Michael,
I'm getting hangs every time I run MoI now...It must be a graphics issue but I've updated my drivers and no luck...
7436.8
Notice I get a weird colour change in the viewport and a freeze...
- Rich
7436.9
I've tried the multi-threading too - no luck
- Rich
7436.10
Actually - looks like MoI was going through integrated graphics - changed to secondary NVidia and seems to be working! Sorry for the stream of consciousness!
- Rich
7436.11 In reply to 7436.7
Hi Rich, that definitely sounds like video driver related problems - maybe when you updated your drivers you only updated the one for one of the 2 video cards in your machine?
It sounds like you've got it worked out now though.
Show messages: All  1-3  4-11
