Selective import
7415.1
Michael, hello!
I have a question: is the file №1 which has a lot of named objects.
There is a file №2, with whom I work.
Sometimes it is necessary to make imports an object from a file in a file №1 №2.
In order not to "mix" two scenes have to close the file №2, open the file №1, it choose the desired object, making it a separate export file №3. Then open the file №2 and only then - do import the file into the scene №3.
Is it possible to (hypothetically in the future) when importing objects from one scene to another scene, select the option to make an imported object name?
To be able to import the object naming selectively?
I think it would be very convenient.
Thanks!
7415.2 In reply to 7415.1
You could also just open MoI twice, then copy and paste objects between the 2.
7415.3 In reply to 7415.2
To BurrMan
The ideal solution when a small amount of the scene objects.
And when a lot of objects, then great, if at least one copy of MOI3D running smoothly.
7415.4 In reply to 7415.1
Hi krass, an "import specific named objects" mechanism could be something for the future but for now the method Burr suggests with opening it up in a separate MoI instance an using copy/paste should get the job done.
7415.5 In reply to 7415.4
Thank you, Michael! I just meant possible future versions of the program.
