Dimension tool (as in sketchup)
 1-4  5-24  25-44  45-64  …  125-138
7403.5
I wrote this script today evening for my friend. It's very primitive, but it's better than nothing. :)
I have no plans to continue developing of this script. Sorry.
EDITED: 7 Mar 2022 by SMIRNOV
7403.6 In reply to 7403.5
I have not the "little Lines" of extremities!
Must I draw them separately ?
And alas we can't use the Helpers lines for align because of the second click ! :)
Seems Scale inactive! ?
French Version http://moiscript.weebly.com/cotations.html
EDITED: 28 Jun 2015 by PILOU
7403.7 In reply to 7403.5
hi Max
Many thanks for this great present .
i don't think that's primitive , for me , it's a major improvement .
Thanks again
Chri from France
7403.8
Very useful - many thanks Max! :)
Hi Pilou:
Me neither.
I guess so. Max?
Any helper lines can be created immediately after starting script but before first click defining location of dimension arrow head #1.
It's activated after 'first click' for arrowhead #1.
Cheers,
Hamish
7403.9 In reply to 7403.8
<< but before first click defining location of dimension arrow head #1.
Ahhh yes! Different than the normal use of a script!
So cool!
<< It's activated after 'first click' for arrowhead #1.
Ahhhh yes! Funny use! So very cool! :)
7403.10 In reply to 7403.5
Hi ..
Showing my ignorance about scripts ..
How do I install this script and use it ?
Cheers, and thanks,
eric
7403.11 In reply to 7403.5
Hi Max, thank you for the dimension script it is very useful.
Cheers!
7403.12 In reply to 7403.10
HI eric (ERICCLOUGH)
first time
You need to copy the two files in the commands folder of MOI
second time
you need to add the shortcut keys and the command :
_dimensions
Chri from France
7403.13 In reply to 7403.12
Thanks Christian,
eric
7403.14
Script update. Fixed few bugs. Changed internal structure. Script modifications should be easier.
Frenchy Pilou
Yes, you should draw them manually.
You can use LockConstructionLine script
var cln =0, gd = moi.geometryDatabase, cl = gd.getObjects().getConstructionLines(), cll = cl.length;
for (var i=0; i<cll; i++) if (!cl.item(i).isTemporary) cln++; if (cln == cll) { gd.removeObjects(cl) } else { cl.setProperty( "isTemporary", false ) }
Bind it to key. Draw construction lines. Run script (the lines will be locked). Run script again to delete the lines.
Hamish, Chri, phlatt5th
Thank you :)
7403.15 In reply to 7403.14
Cool!
French version Updated! :)
7403.16
Max, that's fine!
This is what the Bolsheviks were dreaming! ))))
I download and run the testing. Thank you very much!
You are, as always, is a genius!
7403.17
Forget to say about hidden features.
Double click title to load default values
Double click "Scale" to reset scale.
7403.18 In reply to 7403.17
All day a nice surprise! :)
7403.19
Beautiful script, Max!
as usual... :-)
Thanks for sharing.
Mik
7403.20
Thanks a lot, Max. Its quite usefull.
7403.21 In reply to 7403.14
Hi Max ..
Does this insert into the original script and if so, where?
Or does it replace all or part of it?
thanks,
eric
7403.22 In reply to 7403.21
Maybe like this
Just put it inside the Right Columm of a new ShortCut
but write "script:" on the beginning of the line!
So
script:var cln =0, gd = moi.geometryDatabase, cl = gd.getObjects().getConstructionLines(), cll = cl.length;
Launch the Dimension Script
Call the script of persistant lines
Draw your helper lines
Draw your Dimension
Draw your Dimension
etc
ps I have no more the Button OK that is normal ?
EDITED: 29 Jun 2015 by PILOU
7403.23 In reply to 7403.5
Great job Max, thanks for making this available!
7403.24
Added new arrow types.
The type can be switched dynamicaly by pressing "1", "2", "3" keyboard keys.
Show messages:  1-4  5-24  25-44  45-64  65-84  …  125-138
