Alternative way to enter construction line mode
7395.1
Hi guys. Coming from sketchup, I'm so used to the measure tool that I'm trying to replicate some of its functionality with construction lines.
When drawing Clines, I use the numerical input to specify accurate distances, but it feels awkward having to do that with my left hand while i keep the mouse button pressed with my right hand.
Is there a way to enter construction-line-mode (from within any tool) without clicking and dragging, or is it hardcoded? For example, left click and hold (at the first point) for more than 1 sec--->enters Cline mode. One can then release the mouse button, type in a distance (with the right hand :) ) and click once more to set the direction.
Alternatively, a left click with a modifier button could also be a nice option.
7395.2 In reply to 7395.1
Hi immortalx, sorry there isn't any other way to trigger construction lines other than the hold and drag method.
But you can use a trick that will probably help your distance entering - just type in your desired distance constraint before you trigger the construction line. The construction line then should pick up the distance constraint as long as you are still at the first input point of whatever command you are running. That should hopefully be a bit easier.
7395.3
Thank you Michael, that is an awesome trick! It will take a bit getting used to entering the constraint first, but it is almost what I needed!
Yesterday I found another solution by combining the line and point scripts into one and just cancelling the creation of the line at the end of the script:
#include "GetPoint.js"
function ConstructionPoint()
	var ui = moi.ui;
	var pointpicker = ui.createPointPicker();
	if ( !GetPoint( pointpicker ) )
		return;
	ui.beginUIUpdate();
	ui.hideUI( 'StartPrompt' );
	ui.showUI( 'EndPrompt' );
	ui.endUIUpdate();
	var linefactory = moi.command.createFactory( 'line' );
	linefactory.setInput( 0, pointpicker.pt );
	pointpicker.bindBasePt( linefactory.getInput(0) );
	pointpicker.bindResultPt( linefactory.getInput(1) );
	ui.bindUIToInput( 'bothsides', 'value', linefactory.getInput(2) );
		return;
	//part of Point script here
	var pointfactory = moi.command.createFactory( 'point' );
		pointfactory.setInput( 0, pointpicker.pt );
	pointfactory.commit();
	//Abort line creation
	linefactory.cancel();
ConstructionPoint();
This works wonderfully and adds a point at the typed in distance constraint. The only problem is that I'm left with a bunch of "orphaned" point objects. I'm wondering if it's possible to create those points with a specific style or object-name through that script, so that selecting and deleting them is easier.
7395.4 In reply to 7395.3
Hi immortalx,
Right before the call to pointfactory.commit(), put in this:
        pointfactory.update();
	var output = pointfactory.getCreatedObjects();
	output.setProperty( 'name', 'ConstructionPt' );
That should then make the generated points have an object name of 'ConstructionPt'. If you want to set a style it's a bit more involved, the property you set is the styleIndex which is an integer value of the index of the style to use. To get the style index you'd need to call:
var style = moi.geometryDatabase.findStyle( 'stylename', true /*CreateIfNotFound*/ );
var index = style.index;
7395.5
Thanks again Michael, this worked like a charm!
I'm amazed at how flexible MoI is in customizing the tools and the interface!
