Dual Monitors
All  1-11  12-17
7394.12 In reply to 7394.11
Hi Bima,
> However, can we make the context area appear automatically when we hit the command and
> close automatically when we're done with the command? So we don't use a shortcut key.
Sorry there isn't any easy way to set it up like that because there isn't any way set up for a script to receive a notification that a command is starting or ending.
I would recommend just using the shortcut key once at the start of your program session and then leave the floating context area open after that and not close it.
7394.13 In reply to 7394.12
Okay then.. It would be enough and very nice to me. Thank you very much for your help.
- Bima
7394.14 In reply to 7394.7
I have implemented the separable browser pane as described in this post and it works well for me. One thing that I find frustrating is that if I press the esc key while the browser window has focus it closes it. Is there some way to make the separate browser window persist through an escape key stroke event?
BTW: I'm not sure why I press the escape key as often as I do, I think it may be some sort of subconscious OCD behaviour which I should look to address separately.
Dan.
7394.15 In reply to 7394.14
Michael,
I did a little research and think maybe this code snippet will help but I don't know where to place it.
var myWindow = window.open();
myWindow.onkeydown = function(e){
if(e.keyCode === 27){
e.preventDefault();
7394.16 In reply to 7394.14
Hi Dan, unfortunately I don't think it's possible currently to disable the escape key closing a dialog that has keyboard focus.
The escape key handling happens at a low level in MoI's UI code, so it's not really feasible for a script to try and intercept it.
Once the MoI v4 beta starts up, if you mention this again at that time I could make the keyboard handler look for some property on the dialog and not close it by escape in that case.
7394.17 In reply to 7394.16
Thanks Michael,
I'll keep an eye out for the v4 beta release.
Show messages: All  1-11  12-17
