Extrude Normals
All  1-7  8-13
739.8 In reply to 739.7
WOW!
This is awesome Michael! Great work! Thanks!!!
This will be a huge timesaver for me and I'll definitely be using it every day!
Maybe sometime down the road a similar method might also be used for multi-face sweeps or multi-face scaling too!
Man, when you set your mind to a thing you certainly tend to accomplish it very fast, you truly amaze me.
Thanks again,
MOI just gets better every day!!!!
- 3dvisuals dude
739.9 In reply to 739.8
Yes, that IS AWESOME, Michael - thanks a lot for adding this in!
Building my spaceships and buildings are just getting easier and easier with each addition you make - can't wait for the next release!
-Will
PS - You said you made some fixes with the chamfer command in this next beta, right?
739.10 In reply to 739.9
Hi Will, I haven't quite got to that yet, but it's about next on my list. It's mostly going to be a UI tuneup for chamfer.
I'm trying to squeeze in a few more tuneups like this (and a few last bug fixes) before releasing the next beta because I want it to be pretty much the last beta.
739.11 In reply to 739.10
I understand, and I look forward to it - I'm glad you added those last few modeling tune-ups - I certainly appreciate them!
Besides, I'm looking forward to your documentation as well.
-Will
739.12 In reply to 739.11
Hi Will, I'm tuning up chamfer now and now I figured out what is strange about it in the current beta.
Currently it takes 2 distances, and for every edge it has to figure out which side of the edge should get distance 1 and which side should get distance 2. The way it currently works is that if you have a face selected, or all the edges of a face selected, then that will get distance 1 to the side of that face. Everything else gets distance 2.
But this means that if you have an entire object selected (no faces or edges selected), then everything will use distance2, that's why it feels weird currently with things only having an effect when you change the second distance only, and nothing happening when you change the first distance.
I'm tuning this up for the next beta so that by default chamfer will just have one distance input which will make things easier to control for simple chamfers. There will be a "use 2 distances" checkbox that will let you show the 2nd distance and make things behave the same as the current beta, except I'll switch it so that if no faces or edges are selected everything will get distance 1 instead of distance 2 since that just seems a bit more expected..
EDIT: there is actually another bug mixed in there for the current beta that makes the whole distance1/distance2 thing get fouled up after the first run through as well..
EDITED: 11 Jul 2007 by MICHAEL GIBSON
739.13 In reply to 739.12
Okay great Michael!
For me, a lot of times, nothing would happen when I run the command - perhaps it's because it was expecting a distance2 entry instead of 1 - most of the time I'd just put the same value in both but still nothing would happen.
Hopefully it'll work for me as well as fillet does when you're finished with it!
-Will
Show messages: All  1-7  8-13
