Function to convert to smooth points?...
All  1  2-3
738.2 In reply to 738.1
Hi Will, the main problem is I didn't have a good spot yet in the UI for changing point properties like that, that's why that function won't be a part of V1.
But the way you can do it right now is to insert those new points, then delete the old corner points.
If there is a region of a curve that is currently made up of lines and you want to make it a smooth shape, you might be better off using Edit / Separate to break the segments apart, then delete the lines you don't want and draw a new freeform curve in that spot instead... After you are done drawing new segments in select them all and then use Join to make it back into one curve again.
738.3 In reply to 738.2
Okay thanks, I kinda figured that was my only option at this point - I was just hoping it wasn't something hard to add later.
-Will
Show messages: All  1  2-3
