Easiest way to terminate a sweep?
All  1-16  17-20
7370.17 In reply to 7370.16
Philou
test with your file and it's OK for me...
EDITED: 31 Dec 2020 by FINEMA
7370.18 In reply to 7370.16
Aaaaaaah yes the Right Click don't works! ( I am fan of the Right Click! )
The normal recall function works!
So maybe that will be improved! :)
7370.19 In reply to 7370.18
Yeah the way it happens to work is it splits the edge and then it runs the Blend command. So if you right-click the system thinks the last run command is Blend and re-runs that instead of re-running BlendCap.
I guess the way to improve this would be to be able to pass in an option for moi.command.execCommand() to tell it not to record that one as the last run command.
7370.20 In reply to 7370.19
...out of my competence! :)
Show messages: All  1-16  17-20
