Can't create the bottom of the shoe sole
All  1  2-4
737.2 In reply to 737.1
Hi Thor - in a future version I would like to make a tool that would surface a curve like that directly, but MoI won't have that for version 1.0 .
In general the best way to surface a closed thing like this right now is to dice it up into at least 2 pieces and then do something with those pieces, either loft between them, or use them as rails for a sweep, or part of a network surface.
So what I'd recommend is to first draw a line down the middle like this:
Now select your outline, then run Edit/Trim and select the line as the cutting object. Hit done to keep all pieces.
Now your outline should be split into 2 different pieces. In this case I think a loft between these will get you a good result, select both of the pieces and hit Construct / Loft and push done, to get this:
Sometimes it is easier to make progress by splitting things up like this.
Hope this helps!
737.3
thnx a mil, done it and works fine, post l8r more of the stuff :-D
Thor
737.4 In reply to 737.2
Hi Thor:
To obtain the floor of the sole it uses boolean fusion
1. - Draws in the top view the contour of the sole on a bits map
2.- In the right view draws the profile of floor and te profil external.
3.- Use boolean fusion It eliminates obsolete geometry
Best regards
Juan Galvan
Show messages: All  1  2-4
