editing extruded 2D face?
All  1-3  4-6
7365.4 In reply to 7365.3
Hi Christopher, you may be wanting to use a different kind of CAD program for that type of editing - one that's called a "feature based parametric" CAD program. Those are the ones like SolidWorks or Solid Edge where they keep a list of "features" that went into constructing the object and allow you to edit the features and have the model update.
Those systems can work really well for the types of edits that you are describing. MoI does not currently have the full set of that same functionality, the focus in MoI is much more on just drawing things quickly the first time and not so much on editing built things later on. So in MoI you'd mostly do the workflow that you are describing like edit the curve, re-extrude it, etc... The exception is that MoI does have some limited amount of history in it, if you generate an extrusion from a curve in MoI it is then possible to edit the curve and the extrusion that was created from it will update but not if you have done other operations on the extrusion like additional booleans after the extrusion was finished.
I do want to implement a deeper history function in the future but if that's something you really need a lot right now you would want to look into those parametric CAD programs which are focused on that type of thing right now.
7365.5 In reply to 7365.4
"The exception is that MoI does have some limited amount of history in it, if you generate an extrusion from a curve in MoI it is then possible to edit the curve and the extrusion that was created from it will update but not if you have done other operations on the extrusion like additional booleans after the extrusion was finished."
This is exactly what I want to do! How do I do this, please? :-) I've noticed that when you create a solid via extrusion, the curve you use is left behind. I normally delete this because it gets in the way of easy selection of the solid. Are you saying that if you edit THIS curve, the solid will automatically re-extrude?
I'm familiar with the parametric-type CAD programs you're describing. I've used VectorWorks for many years. I find myself liking the MOI way, where the solid is just the solid as you operate on it and it has no notion of where it's from, sometimes. Sometimes I miss the ability to go back and edit the two cylinders (for example) that the soild is made from. On the whole, I VASTLY prefer MOI, so I'm sticking with it for now. Thanks!
Christopher
7365.6 In reply to 7365.5
Yes! When you edit a generator curve this one remakes the Curve/surface/Volume of any function of the object! :)
Careful : as soon as the object moves or is modified by another thing this link will be dead!
here after an extrude
EDITED: 26 Apr 2015 by PILOU
Show messages: All  1-3  4-6
