Pipe script not working
All
1
2-5
bemfarmer
23 Apr 2015 (2 of 5)
7362.2
In reply to
7362.1
? You must have got the wrong versions somehow ?
http://moi3d.com/forum/index.php?webtag=MOI&msg=6721.4
EDITED: 23 Apr 2015 by BEMFARMER
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Michael Gibson
23 Apr 2015 (3 of 5)
7362.3
In reply to
7362.1
Hi Christopher, yes if I remember right an older version of Pipe only worked with MoI v2.0 and you needed an updated version to work with MoI v3.
There's some info collected here:
http://kyticka.webzdarma.cz/3d/moi/#Pipe
If you're still stuck please post here the 2 files you are currently using for Pipe so I can take a look, there are several versions out there and I'm not sure which particular version you are trying to use which is not working for you.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Message 7362.4 deleted 23 Apr 2015 by DITTO
Christopher (SCHARDT)
25 Apr 2015 (5 of 5)
7362.5
In reply to
7362.2
I thought I HAD copied the right mix of files, but looks like I didn't. When I re-copied from the links y'all provided, it worked! Thanks!
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Reply to All
All
1
2-5
