Pipe script not working
7362.1
I downloaded Pipe.js and Pipe.htm and put them in the commands folder.
Pipe.js is from the "new" Pipe.zip
Pipe.htm is from the "old" Pipe.zip (since the old archive didn't have this file)
I associated a key to execute "Pipe"
I created a circle and hit that key.
What's happening is that MOI seems to be waiting for input. Nothing in the UI has changed appearance. There is no popup alert, but clicking around the model doesn't change selection, like it normally does. Only after I hit the ESC key does the program return to normal function.
Anyone know how to get Pipe working with the latest version of MOI on OSX?
Thanks!
Christopher
7362.2 In reply to 7362.1
? You must have got the wrong versions somehow ?
http://moi3d.com/forum/index.php?webtag=MOI&msg=6721.4
EDITED: 23 Apr 2015 by BEMFARMER
7362.3 In reply to 7362.1
Hi Christopher, yes if I remember right an older version of Pipe only worked with MoI v2.0 and you needed an updated version to work with MoI v3.
There's some info collected here:
http://kyticka.webzdarma.cz/3d/moi/#Pipe
If you're still stuck please post here the 2 files you are currently using for Pipe so I can take a look, there are several versions out there and I'm not sure which particular version you are trying to use which is not working for you.
Message 7362.4 deleted 23 Apr 2015 by DITTO
7362.5 In reply to 7362.2
I thought I HAD copied the right mix of files, but looks like I didn't. When I re-copied from the links y'all provided, it worked! Thanks!
