hotkey for plugin
7355.1
Hallo together,
I want to work with some of Max Smirnov“s great plugins. Thank“s for Frenchy for the wonderfull list.
Is it possible, to make some hotkeys instead of writing the commands in the commandline.
Rudl
7355.2 In reply to 7355.1
Hi Rudl, yup it should be possible to set up hotkeys for Max's plug-in commands.
To do that, in MoI go to Options > Shortcut keys and push the "Add" button in there. In the left hand column that says "Key" put in whatever keyboard character you want to use for launching it. Then in the right-hand "Command" column put in the same thing you are currently typing in at the command line.
If that does not work for you please try to take a screenshot of what your shortcut key setup looks like and post it here so I can see it.
Thanks, - Michael
7355.3
Thank you Michael,
I tried it with two plugins and it functions well.
Rudl
