Nudge command
All  1  2-8
7353.2 In reply to 7353.1
Hi Mike, to use the arrow keys you've got to put in one of the following for the "key" column in the shortcut key editor:
    UpArrow, DownArrow, LeftArrow, RightArrow
And those should be 2 words jammed together, like if you want to set the up arrow key, put in UpArrow and make sure not to put in any space between Up and Arrow, they have to be jammed together.
Does that help any? Please let me know if you still can't get it to work.
7353.3 In reply to 7353.2
Yes that worked great!
Thank you
7353.4
I'm grateful for this thread because I didn't know this script existed. Thanks!
One thought: It would be dandy if "Nudge" knew the angle of the current view and adjusted what left, right, up, and down mean.
eg: If you're looking from the front, up/down map to z-axis movement.
eg: If you're looking from the left, left/right map to y-axis movement.
eg: If you're looking from the back, left/right movement is reversed.
This can work for diagonal views as well by simply figuring out which cardinal axis the view is closest to and modifying direction and polarity of nudging as if the view was directly on that axis.
It would also be great if the default nudge amount was not "1.0" but instead the current grid snap value.
Is this easy to do? ie: Can an iOS programmer with no JS or MOI programming experience figure this out? If so, let me know:
the JS api that gets the current view angle
the JS api that gets the current grid snap value
and I'll do it!
Christopher
7353.5 In reply to 7353.4
Hi Christopher,
This one should be fairly straightforward - you can retrieve the current grid snap value by: moi.grid.snapSize;
So in the place in Nudge.js where it has the nudge amount = 1.0 make it be = moi.grid.snapSize instead.
The view dependent nudge is likely to be quite a bit more complex. You can get the view frame of the current viewport by calling moi.ui.getActiveViewport().cameraFrame
That returns an IMoiCoordinateFrame which a coordinate system with an origin point, and x y z axis directions. In this case the x-axis of the frame will be in the view's direction towards the right, the y-axis will be in the view's upwards direction and the z axis of the frame will be towards the eye point.
There is another call which returns view angles - but there is not just a single view angle like you say, there is a combination of 3: view.upDownAngle , view.leftRightAngle and view.tiltAngle.
7353.6 In reply to 7353.5
Thanks for the tip: "moi.grid.snapSize"!
I believe all I need for what I'd like Nudge to do is
view.upDownAngle
view.leftRightAngle
view.tiltAngle
What units are these in? Degrees?
I assume that upDownAngle==0 means looking in a horizontal direction. Are positive values up or down?
Are positive values of leftRightAngle left or right?
And what is tiltAngle?
Thanks again,
Christopher
7353.7 In reply to 7353.6
Hi Christopher,
> view.upDownAngle
> view.leftRightAngle
> view.tiltAngle
Yes, they're in degrees.
An upDownAngle==0 means you are looking straight downwards, the up/down and left/right angle values are used as in a Spherical coordinate system as shown here:
http://en.wikipedia.org/wiki/Spherical_coordinate_system
upDownAngle is the angle the eye position is rotated downwards around the world xaxis, and left-right angle is the amount it swings left or right rotating around the zaxis.
tilt angle is the angle of rotation around the view vector, like the roll axis angle shown in this diagram (from Wikipedia):
It should follow the right-hand rule with the orientation being the world z axis.
7353.8 In reply to 7353.4
Hi, I've written a 2D version.
It checks which viewport the mouse is over:
https://github.com/thetumbledtype/moi3d-scripts-commands/blob/master/Nudge2D.js
Show messages: All  1  2-8
