Hi Nicola, one other thing I wanted to mention is that if you have an older computer, you can often times upgrade it to perform quite significantly better with only a small cost.
One big factor for display is your computer's video card. If you have a video card that's more than about 5 years old, they just are not very good. Newer ones are anywhere from like 20 to 100 times faster, so it can make a very big difference in the display speed.
MoI is actually designed so that it doesn't really need a fancy video card to work well, just one that is kind of reasonably modern (like less than 5 years old is a pretty good mark).
For example here is one that you can buy online in the US that is only $30, but should run MoI actually quite well: http://www.newegg.com/Product/Product.aspx?Item=N82E16814127181
That's probably the single biggest impact upgrade. The other upgrade that is worthwhile is to increase your system memory (RAM). Many older machines only have 256 Mb or so of system memory, and for CAD work it can get filled up pretty easily. If you can increase the older machine's memory to have at least 512 Mb (or even more if possible), that can also make a pretty big difference.
A memory upgrade for an older machine is also not very expensive, you can get a 256Mb module for just around $30. You have to be a bit careful to get the right kind for your system though.
So with a budget of around $100 you can get a new graphics card + 2 256 Mb modules for 512 Mb of memory, and that will really "juice up" the performance of an older machine by a lot.
