Problem with the trial installation
7326.1
I have a V2 licence, thinking about an upgrade, but i'm not able to install it.
Error message says: "Can't find a file".
Any clues?
marek
7326.2 In reply to 7326.1
Hi marek, I've not heard of that problem before, is there possibly some unusually restrictive file permissions set on some of your folders?
What happens if you right-click the installer file and choose "Run as Administrator", does that make any difference?
Also you might try temporarily disabling any virus checking system you have running, maybe it is interfering with the installation.
7326.3 In reply to 7326.1
If it's virus checker related you might try using the "no save" trial version instead - the regular 30-day trial version is protected by a system called WinLicense and at least one virus checking system (ESET I think) will tend to flag anything protected with that as a virus, maybe that's what you are running into. The "no save" trial version and also the regular full version do not have that on them so if that's the problem they would probably not trigger it.
7326.4 In reply to 7326.3
Yeah, it was Eset nod32.
Thank you, Michael!
marek
7326.5 In reply to 7326.4
'No save' is the only option as after a temporary ESET deactivation during the installation process V3 Trial is still a "virus contaminated" for the ESET.
Too bad, since I'd like to check the best option for importing Moi3D geometry to Archicad where I have the OctaneRender plugin.
Skp and 3ds might be good enough but I'm not able to compare that with the V2 export quality.
Or is it the same?
If so, it might be no reason for me to upgrade.
marek
7326.6 In reply to 7326.5
Hi marek, the export quality would likely be the same unless you were running into bugs. There was not much new specifically for mesh export from v2 to v3 other than various bug fixes.
