Exporting to PDF
All  1-2  3-8
7324.3 In reply to 7324.2
Just spoke to James Elliot who has been a great help to me since he introduced me to the program and has literally just said exactly the same thing. As the object was too far away from the origin point as well as size of the object being an issue so nothing was showing up.
Thanks for answering my question quickly!
Jacob
7324.4
On a related point: I couldn't find anyway to modify curve thickness when exporting to PDF.
Is this a feature you might be able to add please?
- Hamish
7324.5 In reply to 7324.4
Hi Hamish, there is a method for controlling curve thickness for the PDF export - to use it click the "Line style options" button that shows up on the PDF export options dialog here:
Then inside that Line style options dialog, there are entries for Width that you can edit, those values set the line widths that are used in the PDF file. They are in typographic "point" units which is the native unit system used in PDF:
7324.6 In reply to 7324.5
Thanks, but I seem to be missing those PDF export UI options.
Here's all I see after clicking export, selecting *.pdf and entering the file name to save as:
Just to be sure I'm looking in the right place: I don't see any PDF export options under the Options > Import/Export tab. The screen captures you posted aren't from that location are they?
Cheers,
Hamish
7324.7 In reply to 7324.6
Hi Hamish,
Nope, they're just from the regular dialog that pops up on save.
But the options that I showed before will only be displayed if you are doing a hidden line drawing generation by exporting solids and surfaces as part of the PDF export, if you are exporting only wireframe curves alone those options won't show up.
There is not currently any way to modify the line thickness for a wireframe curve export, that's set to only use a width of 1.0, with colors and layers coming from style assignments.
7324.8 In reply to 7324.7
Thanks! That explains everything :)
In case anyone is interested, here's a work-around to 'Export Selected' or 'Save As' wireframe curve objects with any desired line width to PDF:
- Create a single small planar object anywhere in the drawing - even a 0.0001 x 0.0001 mm square seems to work.
- Either initiate 'Save As' command or select the planar object and desired wireframe curve(s) and initiate the export process.
- VoilĂ ! - the otherwise missing PDF export options are now available.
- Select 'Generate outlines' (only) and set the desired line width using: 'Line style options' > 'Visible lines': Width, (NOT 'Line style options' > 'Outlines').
Inspecting the generated PDF using Nitro PDF, I find the small planar object never gets exported.
- Hamish
EDITED To highlight use of the 'File > Save As' command.
EDITED: 11 Feb 2016 by HAIRYKIWI
Show messages: All  1-2  3-8
