Need help that MoI meets Z88
 1-12  13-32  33-38
7323.33
Hi Max, Hamish and all.
Today I was trouble shooting.
Max >
There is a filechecker in Z88. Something was wrong with z88i1.txt.
In my old handbook where in line 1: two flags with 0
Now it should be: three flags with 0.
Please don´t ask me why.
Sorry Max!
Hamish >
Next problem was with z88i2.txt.
Not only the nodes has to follow 1234. Also the boundary conditions
has to follow xyz.
For example:
50 3 1 4000
50 1 1 -2500
this is wrong
shut be
50 1 1 -2500
50 3 1 4000
Then z88 tells me that my structure is not corect with its static.
Could not find my mistace. It needs to much time for searching
so I will make tomorrow a more simple construktion where I can
test my 28 condition file and more with.
Good news are that with Max´s script we are also able to use the
two types of bar. Number 2 and 13.
Calculating of straigth spars are possible with it.
Helpfull for this would be a script that gives the moment of inertia from cross sections.
In MoI we draw a face. Some cad systems has it.
One year ago somebody from the Uni Bayreuth told me the make a new software that handle the other direction
of FEM. You set the load and the anotations and the software forms the part.
I believe it will be also freeware.
Bye till tomorrow
Hans
7323.34
Hi at all.
Today I had to made many tests. Z88i1.txt was o.k. With three times a zero at line 1.
Z88i2.txt was also o.k. There is a filechecker in z88 for proving.
When I start to run the calculation z88 allways told me that my static is not corect.
So I made a more and more simple structure step by step. Five or six times. Allways the same problem.
Then I made a simple cranestructure. > Everything was running for the first time.<
If we look at the crane drawing we see that the nodes have growing numbers along the x-axis.
This depends on the way the drawing was made. With Array in one direction.
The Biplane drawing is in its nature a more chaotic system.
We see this how the node numbers are placed.
In the old way with dxf files we had to draw twice. First the chaotic (normal) way to create the structure.
Then from one end along x to the other end allways left around line after line. The FEM way.
Max> may it be possible to choose the points with [ get points] and then to click all the lines in the rigth order bevor
we start the script?
And then the scipt read it on the same way?
I´m shure that will help.
Now we have: the simple structure, z88i1.txt from it, z88i2.txt. and z88o3.txt.
Z88o3.txt shows all the tensions in the struts between the nodes.
The tools I used: MoI,
JFE -JensFileEditor- a free english version is in the net.
It opens Max´s script direct in in the rigth way.
A capture programm to make the plotting pictures.
Word for its search and replacement funktion.
We need it for editing z88o3.txt.
search ^p^p
replace it with ^p
It makes z88o3.txt shorter.
then we use JFE to marking vertical all the +/- loads of the struts and save them in a new file.
Later we set every content (loadcase) in an Excel sheet.
We also make a folder structur for every loadcase.
When all the little problems are solved I have to make a summary of the calculation process.
This is my weekend result.
Your optimistic Hans
Size: 110.7 KB, Downloaded: 21 times, Dimensions: 1280x978px
Size: 77.6 KB, Downloaded: 10 times, Dimensions: 1280x978px
7323.35
Hi Max,
a new idea to handle the drawings could be to draw first the structure in the "chaotic way", then set the points more directed and after this
to delete the lines step by step and draw the structure again in a FEM mode.
It needs only a few minutes.
This evening I make test and give you the result.
Hans
7323.36 In reply to 7323.35
Hi Hans
Sorry, I was busy last days. Today I'll read all your messages and write answer.
7323.37
It seems for me that MoI gives the elements back to the script in the same sequence
like they have been drawn.
So I used the new procedure of drawing.
First I was drawing a simple structure in the most possible chaotic way.
Then I placed the points left around the frames along X.
I deleted two or three lines again and again and drafted they new in the same manner (left around).
Every time I chanched the stile to red.
After finishing the structure I used Max´s script.
The result was o.k. The structure was much more aligned.
At next I try more complex frames.
Good night for now
Hans
7323.38
Sorry, but the last two weeks I didn´t have enought time.
After the first of May the whole situation will be better. Than I go into my retirement.
Last thursday I had a good conversation with the guys from the Bayreuth University
at the Hannover Fair.
They want to help us with our files and there is a reason to do that.
At the beginning of our projekt the tests have been made with the version I have allways used. Z88100.
You know it was partly successfull. I have installed the new version Z88OS14 and it can not read z88i1.txt from your script.
I don´t know why.
You can see the result. Bevor few minutes we (uni bayreuth and me) had a conversation about
the problem. They are optimistic that we together find a way to connect MoI and Z88.
But it seems that we need a little bit more time.
Max, please explain me how your script read the information from MoI.
Now I send some files to Bayreuth. Then you will have all information from me.
The hopefully Hans
(biggest fan of nodes)
Show messages:  1-12  13-32  33-38
