surface blend won't always join with other surfaces? but will in Rhino?
7318.1
Hi
When I create a blend between surfaces , it does not always want to join with the rest of the model. It will join in Rhino. Has anyone else had this problem?
Mark
7318.2 In reply to 7318.1
Hi
post an example ;)
7318.3 In reply to 7318.1
Hi Mark, maybe the join tolerance is set to be looser in Rhino. But it's difficult to know what's going on without seeing the actual geometry, can you please post a 3DM model file in it with the edges you are blending between when you see this problem? If it's a blend bug I will need to be able to recreate the blend in order to examine what is going on.
