thank you for your fast response.
I'm not sure if i undestand it correctly.
I'm place the data (working in mm) in the upper right area from the origin point on the grid (from 0 to x=210 and Y=297 or any other formats)
The result isn't an DIN A4. The result is 215,9x279,4 mm. I want use the entire space of an Din A4 document. Is this possible?
We need to use the option "preserve units" to measure cut and design graphics on to the PDF-document as base.
Jörg
Das Leben ist ein Spaziergang. Manchmal bei beschissenem Wetter ;) |
