Mutual Trim\Extend skipping "Done" Dialog
7306.1
Hi.
Was wondering if there it's possible to edit the Trim and Extend commands so that when it's mutual it skips the "Done" dialog.
I am often using mutual trims and extends so that would come handy.
M.
7306.2 In reply to 7306.1
Hi Max, try these attached customized commands named "TrimMutual" and "ExtendMutual" - these only do the mutual mode and have that extra stage to trigger it eliminated.
7306.3 In reply to 7306.2
Thanks a lot Michael,
our savior.
M.
7306.4 In reply to 7306.2
The Extend-skip-done works, though the trim-mutual-skip-done is not really complete?
That one skips the initial "select which type of trim" and goes straight to mutual, though stops there waiting for a done, as if you want to select pieces to "keep or remove", which I guess is a shortened version of the trim command, useful.
But shouldn't it just do the mutual trim and end? Maybe I misread the original post. Keeping the 2 added commands congruent though, it should just end I think.....
7306.5 In reply to 7306.4
Hi Burr, the way I read the request was to only remove the part of Trim where you have to signal you want to do a "mutual trim", not to also remove the part where it asks you for pieces to discard or whether to keep them all...
I guess Max would need to clarify if he wanted that removed as well, but often times in 2D drafting when you are trimming it's to delete pieces and being able to pick pieces to delete inside the trim command can be a bit nicer than having to do it separately...
But if you do want a version of TrimMutual that also skips the last "pick pieces to discard" step and just generates all the pieces, try the version attached here instead.
