MOI 3.0 upgrade question
All  1  2-6
7297.2 In reply to 7297.1
Hi Bob, if you've lost your v3 license key I have a page here where you can get it:
http://moi3d.com/reinstall.htm
There are 2 functions on that page - on the bottom part you can put in your e-mail address and have your license key looked up and sent to you through e-mail and on the top part you can put in your license key and get a new download of the installer.
If you are not able to get your license key from there, please contact me through e-mail at moi@moi3d.com
7297.3 In reply to 7297.1
Hi Bob - also another method for looking up your license key is to go to your old PC where you have V3 installed, hold down Win key + R to get the "Run" dialog, and inside there put in:
%AppData%\Moi
That will then open up the folder where MoI stores license keys - there will be a file there named moi_v3_license.key which you can open up in notepad to view your v3 license key.
7297.4 In reply to 7297.3
Thank you!!!
Last month, on a home network, with laptop beside new motherboard and new hard drive being set up, I noticed that a second copy of Moi, on the laptop,
for purposes of setting up scripts, would open and then give a polite message about having only one license, and then the second copy closed.
Normal behavior, I believe.
EDITED: 11 Mar 2015 by BEMFARMER
7297.6 In reply to 7297.5
Hi Brian - yes you can have the same one license installed on as many machines as you want, just as long as it's only actively launched and running on one of those at a time.
Show messages: All  1  2-6
