Modeling Challenge
All  1-2  3-6
7292.3 In reply to 7292.1
Hi libelle, also if you'd like the try the sub-d modeling approach but within MoI, it's possible to do that using Max Smirnov's plugin which you can get from here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6674.203
Then you construct an initially blocky object made up of all planar quad faces in it, then run Max's sub-d smoothing command on it and you will get a melted down smoothed result, see the attached file where I've done it that way.
Branching structures in particular tend to be easier to do in sub-d modeling.
7292.4 In reply to 7292.1
7292.5
Thanks Michael and BurrMan!
I considered modeling in another program and importing, but I just wanted to see if anyone had an approach. I've only been using MoI for about four months, so I'm still learning its capabilities. And I'm always impressed with the resourcefulness of the people in this forum!
BurrMan, thanks for the tutorial. I really appreciate the video - I'm not sure I would have been able to follow if you had written a text description, but your demonstration made it quite clear.
I appreciate the help!
7292.6 In reply to 7292.5
I would suggest searching for something like "solidifying wireframe" or "wireframe thickening" and (also) having a look at the result's images.
Show messages: All  1-2  3-6
