Point reduction script?
All  1  2-3
7291.2 In reply to 7291.1
Hi Lordfox
There is a rebuild command which enables you to nominate the number of points to use to reshape a curve(usually to make it smoother).
To use it select the curve, hit the TAB key which moves the cursor to the numeric input box, type "rebuild" and press enter and a dialog will appear in the properties panel allowing you to specify the number of points to use to rebuild the curve.
Hope this helps.
Mal
7291.3
Thank you, I know the rebuild-tool (for generating curves from edges) - :) but this is new for me, thnx, I will try
Show messages: All  1  2-3
