Hello dear users, is there a good point reduction script for moi3d v3? Because I have made a curve from a surface, but I wish to have better point control, with less points. Like in Illustrator - there is also a point reduction tool :)
There is a rebuild command which enables you to nominate the number of points to use to reshape a curve(usually to make it smoother).
To use it select the curve, hit the TAB key which moves the cursor to the numeric input box, type "rebuild" and press enter and a dialog will appear in the properties panel allowing you to specify the number of points to use to rebuild the curve.
