Shortcut to open snap menu
7277.1
I hope I am not bothering (too much) and I admit it is not important (at all), but since the shortcut I found on Petr's site and here on the forum seems to be 7 years old I thought maybe something has changed meanwhile.
To open my snap menu I use this snippet:
var cb = moi.ui.getUIPanel('moi://ui/CommandBar.htm');
moi.ui.showMenu( 'ObjectSnapMenu.htm', cb.document.body.lastChild.lastChild, 2, 0 );
Is it also possible, maybe by firing an UIEvent to open it the same way a mouse click would do? I mean, is there a shortcut that opens it this way:
7277.2 In reply to 7277.1
Hi Strube, it's possible to do that, the script has to dig into the UI to retrieve a reference to the grid snap button and pass that to showMenu() - the structure of the UI changed from v2 to v3 and so that old script only worked to find the button for v2.
Try this instead for v3:
script: /* Show snap menu */ moi.ui.showMenu( 'ObjectSnapMenu.htm', moi.ui.commandBar.document.getElementsByTagName( 'moi:StateButton' )[2], 2, 0 );
7277.3 In reply to 7277.2
Wow, nice, I hadn't been able to find the "moi:xxx" elements either.
But, of course, the same had to be tested for the file menu:
moi.ui.showMenu( 'FileMenu.htm', moi.ui.commandBar.document.getElementsByTagName( 'moi:CommandMenuButton' )[0], 2, 0 );
And it looks somewhat unfinished:
Can I perhaps make it look like this:
What I tried is stuff like this:
var elem = moi.ui.commandBar.document.getElementsByTagName( 'moi:CommandMenuButton' )[0];
var evt = new MouseEvent("click", {
    bubbles: true,
    cancelable: true,
    view: window,
elem.dispatchEvent(evt);
But it keeps saying "'MouseEvent' ... is not a constructor.", which seems to be a bug in Qt4 Webkit. (Which also happens for "Event".)
7277.4 In reply to 7277.3
Hi Strube,
Sorry no I don't think you can get the little arrow thing to be displayed programmatically - it's built into menu launching buttons that when the button enters the hover state it will show that menu launcher arrow thing above it. I don't know if there is any general way to set the hover state from script, it's not quite the same as triggering event handlers. I think it's only something that gets set in response to actual mouse events.
7277.5 In reply to 7277.4
Ok, thanks, Michael.
