Flyout menus (very often) opens at center of screen (under wine 1.4.1).
All  1-5  6-11
7273.6 In reply to 7273.5
That sounds great, Mark. I use 1.4.1, because Michael suggests using it and I had problems with the latest stable and some older dev version.
Do you have any other problems? Like strange bold fonts or so?
7273.7 In reply to 7273.6
No I don't have any other problems. For certain font sizes, the gui font appears weird but for the size I normally use it looks fine. I am a moi newbie so I have not used all the program's capabilities but all the basic stuff works great.
Cheers,
Mark
7273.8 In reply to 7273.7
Thanks, Mark. Right now even 1.7.37 is the latest dev version and I couldn't see any bold fonts at all.
Also, this is fast now:
var sp = moi.ui.getUIPanel('moi://ui/SidePane.htm');
var st = sp.document.body.style;
if (!st.display || st.display == 'block') {
    st.display = 'none';
} else {
    st.display = 'block';
moi.ui.mainWindow.contentChanged();
(Under 1.4.1 this looked like running on a Pentium 2 or so.)
7273.9 In reply to 7273.8
Hi ttype,
Err, forgive my ignorance, what does that snippet of code do and how do you run it?
Cheers,
Mark
7273.10 In reply to 7273.9
You could run it as a keyboard shortcut, it toggles the visibility of the side panel on and off.
But I just mentioned that, because Michael probably reads it. And now he knows, that not just the font thing is better in 1.7.37.
7273.11 In reply to 7273.10
Hi Strube, that's great news that there are other improvements in the latest dev version!
Show messages: All  1-5  6-11
