Blender and Moi are good friends now
7270.1
hi,
blender 2.74 will be able to import and use the normals as
generated by the CAD soft.
http://wiki.blender.org/index.php/User:Mont29/Foundation/Split_Vertex_Normals/Custom_Split_Normals_Manual
i show you a test with a nigthy build
https://builder.blender.org/download/
the outlined object use the new improvement => no bad artifacts
7270.2 In reply to 7270.1
That's great news Lawrence, that will be a significant improvement for Blender for rendering CAD data!
7270.3 In reply to 7270.1
That's great, thanks for letting us know.
Now we just need a tool in MoI to tell which way the surface normal is facing.
~Kevin~
Only for FBX export from CAD ?
<<< Some tools, in particular CAD ones, tends to generate awful ugly geometries when tessellating their objects into meshes (very thin and long triangles, etc.). Auto-computed normals on such geometry often gives bad artifacts, so it is important to be able to import and use the normals as generated by the CAD tool itself.
There is now the needed helpers in Blender RNA, which allows import scripts to set custom normals from read data. Currently, only FBX importer uses it.
7270.5 In reply to 7270.4
Bonjour French Pilou
ça fonctionne aussi avec l' OBJ importer, je l'ai testé.
it runs also with OBJ Importer
http://wiki.blender.org/index.php/Dev:Ref/Release_Notes/2.74/Addons
https://developer.blender.org/rBAcfdf95dc8a0eae
you can try by yourself with daily builds :
cool news!
7270.7
Hi
7270.8 In reply to 7270.7
Ha that one looks familiar Lawrence! :)
7270.9 In reply to 7270.7
Extend looks like a corkscrew
7270.10
Hi Michael
small tribute to your great MoI !
Hi Max
same problem with circles , they look like ellipses when you do not look them in the face :)
thanks to you for customUI, subdiv and other !
