Failed to Save.
All  1-2  3-13
7266.3 In reply to 7266.1
Hi Mindset, sorry you did not get your file saved. Right now there isn't anything in place to guard against that, mostly because I just haven't heard about someone running into that particular problem before now.
I've added a note on my todo list for MoI v4 to pop up an error message if the save was unsuccessful. In the meantime if you have an external drive that has a loose wire and gets easily disconnected or something like that, you may want to copy your files onto the computer's built in disk and work on your file from there and copy it back again at the end, rather than opening it directly from the external drive.
Sorry for the difficulty, - Michael
7266.4 In reply to 7266.2
Hi Danny, under normal circumstances just checking the asterisk like you say should work. But in the presence of a total disk failure as happened here I think the asterisk will disappear even though the file was not actually saved. That's certainly something that I should fix for v4.
So for v4 on disk access failure for a save, I'll put up some error dialog and also not let the asterisk get cleared either.
7266.5
Thank you all,
Is there some way to work on files while they are stored on Google Drive?
7266.6 In reply to 7266.5
Hi Mindset,
I think so - doesn't Google drive work by monitoring files you store in a particular folder on your regular drive and then when those change it copies the updated files to Google's server?
If that's the way it works (I don't use it myself so I'm not really familiar with it) then just work on the files in your local folder as you would any other file.
7266.7
Hello Michael Gibson,
You mentioned earlier in this thread about making a change in Version 4 to address this issue.
Well, even though I don't know what other features Version 4 may introduce, be assured that I will feel as blessed to buy your next version as do I feel about having purchased this version and the prior.
Thank you Mike, for your good work.
7266.8
Never scripted on the form before... but...
Might something like this work?
myActiveXObject = new ActiveXObject("Scripting.FileSystemObject");
try {
file = myActiveXObject.GetFile(doc);
catch(err) {
moi.ui.alert(err.message);
var before = file.DateLastModified;
moi.geometryDatabase.save();
if (before == file.DateLastModified)
var msg = 'Failed to Save:\n\t' + doc
moi.ui.alert(msg);
I don't really know how to handle an error and get out cleanly.... just hope maybe this is a worthy attempt.
EDITED: 21 Feb 2015 by IGNITER
7266.9 In reply to 7266.8
Hi Mindset - something like that could work but unfortunately there tends to be security problems with using Scripting.FileSystemObject on newer Windows versions, and it's not present at all on the Mac.
I don't think it's easily solved by scripting alone, for v4 I will be adding support for catching writing failures directly into the file writing code.
7266.10 In reply to 7266.9
Thank you Sir.
7266.11 In reply to 7266.3
Hello Michael,
I am wondering if the "pop up an error message" feature for an unsuccessful model-file Save made it into V4?
BTW...
I love your software.
It is the best intangible product since the Beatles.
-- MindSet
7266.12 In reply to 7266.11
Hi Mindset,
try to open an instance of Moi and copy the file to the instance and save the scene.
Hope it works!
Das Leben ist ein Spaziergang. Manchmal bei beschissenem Wetter ;)
7266.13 In reply to 7266.11
Hi Mindset,
Not quite yet but it shouldn't be much longer before I'll be able to get to it.
Show messages: All  1-2  3-13
